Deleted all services, but cannot delete host
GEAviation-PBN
Post by GEAviation-PBN »
Hello.
NagiosXI is running on a CentOS VM, manual install. Just upgraded to the latest version today.
Using CCM...
I have deleted all services associated with this particular host I want to delete, but when I hit delete, I fails with the following message...
Database Relationships for host : XXXXXXXXXXXXXX
Items labeled as: 'Dependent relationships' will prohibit deletion
Object ID: 10 of table tbl_host:
No dependencies left as far as I can tell... it jsut won't delete the host record from the DB. There is an alarm for this host, as I have shut the server off, is this related? I went in and acknowledged the alarm, but that didn't help.
Thanks in advance.
~JVC
GEAviation-PBN
Re: Deleted all services, but cannot delete host *resolved*
I read the other post with same issue as me and found the resolution. Sorry... I did do a quick search on the issue and had found the same issue until after I posted.
Thanks.
