User NRPE to monitor multiple Windows Server Services
bryceee
Post by bryceee »
nsclient.ini
(21.37 KiB) Downloaded 562 times
We are currently running Ubuntu 14.04 and Nagios 4.0.7 with NSClient++
Is there away to monitor multiple windows services in one rule
I want to to be able to use a check_command like check_win2012_services to monitor 5+ services.
Currently I can only get them to work one by one like so, this is defined in the host file(Server) on Nagios
#Define a service to Check a Windows Service
use windows-server-service
host_name PERSPLUNK01
service_description Splunkd Service
check_command check_win2012_service!Splunkd
service_description SplunkWeb Service
check_command check_win2012_service!splunkweb
The command I am using looks like this
# CheckService
command_name check_win2012_service
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckServiceState -a ShowAll "$ARG1$"
I know it was possible when we used check_nt.
Do I need to do something on the remote hosts site (where NSclient++) is installed
I appreciate the assitance, been hitting a brick wall on this.
Bryce
Re: User NRPE to monitor multiple Windows Server Services
Post by slansing »
I don't see a "CheckServiceState" defined anywhere in there for NRPE commands, I believe that is the check_nt module call used for services. If you are trying to check them with NRPE you will need to provide a plugin which has the capability of doing this, which I have not been able to find whilst looking around. You may need to write your own based off someone elses, which we can help with a bit.
bryceee
Post by bryceee »
okay I have managed to get the 6 services I need to monitor in one rule.
I had to use 6 arguments
The command file looks like so
# Check Windows 2012 Services
command_name check_win2012__service
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckServiceState -a ShowAll=long "$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$" "$ARG5$" $ARG6$"
And on in the Server I defined it looks like so
#Define a service to "Check Windows Services"
service_description Windows 2012 Server Services
check_command check_win2012_service!DNS Client!Netlogon!Remote Procedure Call (RPC)!Remote Desktop Services!Remote Desktop Configuration
Post by slansing »
Looks good, are the checks coming in properly?
bryceee
Post by bryceee »
Yeah it actually is working, don't mean to sound so surprised. I am just new to this.
Tested it by turning services on and off at random and it flags it.
Sounds great! I'll be closing this thread now, but feel free to open another if you need anything in the future!
