I need a help with one of the error that we are facing after configuring and adding Cisco Catalyst 3560X-48PF switch in Nagios monitoring.
"No Environmental data found : UNKNOWN"
Do anybody know that what can be the reason for this error?
Thanks in advance.
No Environemental data found : UNKNOWN
Re: No Environemental data found : UNKNOWN
What is producing that error? Can we see the command you are running from the CLI to check that switch?
