I noticed today I can't delete hosts by clicking the X in the Actions menu. I can still delete it using the check box and then selecting delete from the "with checked" menu. See screenshots for examples.
Using the actions menu, it appears to think there are dependent relationships when there are not:
Using the checkbox works fine:
Edit: Version 2014R1.4
possible bug in CCM with deleting hosts
- snapon_admin
Re: possible bug in CCM with deleting hosts
It is a bug that has been fixed in the next version.
