Configuration verification failed during apply configuration
cloudcom
Post by cloudcom »
We have a problem with saving new configuration on service management screen. First we created our own command to get the interface status infos of servers.
($USER1$/check_snmp_int.pl -H $HOSTADDRESS$ -C $ARG1$ -n $ARG2$)
Then, we have added a new service using our this new command on the service management tab as below screen.
We saved the changes and clicked the apply configuration button. Configuration varification fails.
What should we do?
Thanks.
Re: Configuration verification failed during apply configura
Go to the Core Config Manager and in the left-hand side under Tools you will see "Write Config Files". Click that, and then click Write, then Verify, and send us the output of the Verify.
cloudcom
Post by cloudcom »
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/172.16.100.252.cfg', starting on line 79)
Nagios Core 4.0.5
Last Modified: 04-11-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in host type objects (config file '/usr/local/nagios/etc/static/check_mk_templates.cfg', starting at line 88)
Warning: failure_prediction_enabled is obsoleted and no longer has any effect in service type objects (config file '/usr/local/nagios/etc/static/check_mk_templates.cfg', starting at line 157)
Thanks and regards
Did you add this service to a host? Click on the "Manage Hosts" button under "Service Management", add the service to a host, save, and try to apply configuration again.
cloudcom
Post by cloudcom »
Hi lmiltchev,
Thanks for the support. I have not configured the "manage host" section. After adding host, I got fail again but this time I used the "write config files" and "verify" and saw that alert settings, check settings were blank. So,
I have learnt how to figure out a problem and how to add a service :D
Now, It works.
Thanks!
I am glad I could help! :) Locking the topic.
