How to monitor content after login and click menu item
bhadre
Post by bhadre »
Hi All,
How to monitor content of the website after login will display menus.
I need to monitor some specific menu Item and specific portlet item
Bhadregowda
Re: How to monitor content after login and click menu item
For complex logins, you might consider using webinject:
http://www.webinject.org/plugin.html
It can be a bit confusing at first, but it is pretty flexible once you get the hang of it.
