Into what file does this go? This is the confusing part do I have to define each host/service for this? For example if I have 44 servers I am checking, that is 44 extra lines I will have to add to the templates.cfg or services.cfg
The only difference between what I wrote and what you already have is the addition of the "!MaxWarn=80% MaxCrit=90% ShowAll type=physical" to the end of your command line in your windows.cfg file.
Gotcha, I'm already part of the way in I just happened to notice that the memory checking was incorrect using check_nt command so I googled around and found this was more efficient. But when I added it like you stated and that is what I gathered from searching, I need to define it somewhere. Disregard the pervasive warning
Error: Service check command 'check_nrpe!checkMem!MaxWarn=80% MaxCrit=90% ShowAll type=physical' specified in service 'Memory Usage' for host 'STLSMS' not defined anywhere!
[root@nagios var]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Pervasive' on host 'STLSMS' (config file '/usr/local/nagios/etc/objects/windows.cfg', starting on line 147)
Checking objects...
Checked 69 services.
Checked 10 hosts.
Checked 2 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 72 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 10 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
Error: Service check command 'check_nrpe!checkMem!"MaxWarn=80% MaxCrit=90% ShowAll type=physical"' specified in service 'Memory Usage' for host 'STLSMS' not defined anywhere!
