System Errors post MYSQL migration
gravitas
Post by gravitas »
I am running VMware Image of XI on a 64 bit system latest version.
I migrated mysql of the the server as per your instructions. Since then:
1. Last Check/Next Check do not change (they are 3-4 days old)
2. I cant apply any new changes, its just sites there
3. I can add new hosts/services but they dont show up even if i can find them under CCM - hosts/services
The thing is I do see the checks go out:
tail -f /var/log/messages
nagios: HOST ALERT: O1 - TOCPO1 - WAP01;UP;HARD;1;OK - 10.43.9.253: rta 3.438ms, lost 0%
Please let me know
abrist
Red Shirt
Re: System Errors post MYSQL migration
Post by abrist »
Something must not be configured correctly through the offload as it sound like the system either cannot write or cannot read from the remote db. Can you post the following files from the XI server:
/usr/local/nagiosxi/html/config.inc.php
/usr/local/nagios/etc/ndo2db.cfg
/var/www/html/nagiosql/config/settings.php
And the following file from the remote db server:
/etc/my.cnf
