Hi All,
Please can someone help me how I can disable or delete the network device from Nagios XI dashborad.
Shailesh
Remove the network device from NagiosXI
Re: Remove the network device from NagiosXI
Typically to remove a device from the main Nagios XI page you will need to remove or disable it in the Core Config Manager. If you are truly talking about a dashboard in the Nagios XI sense, then the dashlet should have an icon in the upper-left that allows you to remove it from that dashboard.
shailu2014
My issue resolved,
Thanks & appreciate for help.
Sjain
Sjain
