I'm trying to run the following command to check the status of MySQL on a remote Ubuntu server:
/usr/local/nagios/libexec/check_nrpe -H remote_ip -c check_init_service -a mysql
The output it returns is:
NRPE: Unable to read output
If I do the same but replace mysql with apache2, then it returns:
Apache2 is running (pid 2973)
This would suggest an issue specifically with checking the status of mysql, but I'm not sure what could be causing this.
The Nagios server is running on CentOS 6 and the client is running on Ubuntu 12.04 64 bit.
Any suggestions would be appreciated.
Thanks.
Problem with the check_init service
Re: Problem with the check_init service
You may be looking for "mysqld" try:
Since it works with apache, we can all but discount it being a configuration issue in your nrpe.cfg, but in any case, can you post your nrpe.cfg file, as well as the common.cfg file? They are responsible for the remote configuration that your Nagios server confers with.
Can you run the check locally on the remote host and post the output?
I've run the following from the Nagios client:
/usr/lib/nagios/plugins/check_init_service mysql
and this returned:
mysql start/running, process 2362
This is what the nrpe.cfg file looks like:
and this returned:
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number. The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nagios/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon.
# Note: The daemon only does rudimentary checking of the client's IP
# address. I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1,nagios.server.ip
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed. This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=1
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo. For this to work, you need to add
# the nagios user to your /etc/sudoers. An example entry for alllowing
# execution of the plugins from might be:
# nagios ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password. If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run. Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on! The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory. Also note that you will have to modify the definitions below
# to match the argument format the plugins expect. Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_load]=/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_hda1]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/hda1
command[check_zombie_procs]=/usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_total_procs]=/usr/lib/nagios/plugins/check_procs -w 150 -c 200
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'. This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
#command[check_users]=/usr/lib/nagios/plugins/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/lib/nagios/plugins/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/lib/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/lib/nagios/plugins/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# local configuration:
# if you'd prefer, you can instead place directives here
include=/etc/nagios/nrpe_local.cfg
# you can place your config snipplets into nrpe.d/
# only snipplets ending in .cfg will get included
include_dir=/etc/nagios/nrpe.d/Re: Problem with the check_init service
This is the common.cfg file:
This is the nrpe.cfg file:
I ran this on the remote host:
which returned:
### GENERIC SERVICES ###
command[check_init_service]=/usr/lib/nagios/plugins/check_init_service $ARG1$
command[check_services]=/usr/lib/nagios/plugins/check_services -p $ARG1$
### MISC SYSTEM METRICS ###
#command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_users]=/usr/lib/nagios/plugins/check_users $ARG1$
command[check_load]=/usr/lib/nagios/plugins/check_load $ARG1$
command[check_swap]=/usr/lib/nagios/plugins/check_swap $ARG1$
command[check_cpu_stats]=/usr/lib/nagios/plugins/check_cpu_stats.sh $ARG1$
command[check_mem]=/usr/lib/nagios/plugins/custom_check_mem $ARG1$
### YUM UPDATES ###
command[check_yum]=/usr/lib/nagios/plugins/check_yum
### DISK ###
command[check_disk]=/usr/lib/nagios/plugins/check_disk $ARG1$
command[check_ide_smart]=/usr/lib/nagios/plugins/check_ide_smart $ARG1$
### PROCESSES ###
command[check_all_procs]=/usr/lib/nagios/plugins/custom_check_procs
command[check_procs]=/usr/lib/nagios/plugins/check_procs $ARG1$
### OPEN FILES ###
command[check_open_files]=/usr/lib/nagios/plugins/check_open_files.pl $ARG1$
### NETWORK CONNECTIONS ###
command[check_netstat]=/usr/lib/nagios/plugins/check_netstat.pl -p $ARG1$ $ARG2$
### APT UPDATES ###
command[check_apt]=/usr/lib/nagios/plugins/check_apt $ARG1$Code: Select all
# LOG FACILITY
log_facility=daemon
# PID FILE
# PORT NUMBER
server_port=5666
# SERVER ADDRESS
# NRPE USER
nrpe_user=nagios
# NRPE GROUP
nrpe_group=nagios
# option.
dont_blame_nrpe=1
# DEBUGGING OPTION
# syslog facility.
debug=0
# COMMAND TIMEOUT
command_timeout=60
include_dir=/etc/nagios/nrpe.d//usr/lib/nagios/plugins/check_init_service mysql
which returned:
I've managed to resolve the issue now.
I had to run the check_init_service command with sudo and add it to the sudoers file.
