Check_Logfiles Plugin Help
allanhillier
Post by allanhillier »
Hi All,
I'm still working through getting Nagios working correctly on our system here at work. I have been using the Check_Logfiles plugin to monitor /var/log/messages and the Oracle Alert log. I have another log file that I wish to check that has a date stamp on it in its name that changes daily. It is DEBUG_2014_09_16.log today and will be DEBUG_2014_09_17.log and so on and so on. My trouble is how do I set it up in the config file? I tried using the following in my config file with no success. I don't want to have to create a script to handle this I wouldlike to accomplish it in the config file. I searched google relentlessly with no help.
@searches = ({
tag => 'debugalerts',
m= `date +%Y-%m-%d`
logfile => '/tmp/DEBUG_$m.log',
criticalpatterns => [
'Device Error',
'System Error',
warningpatterns => [
'Device Stalling ',
Any ideas would be greatly appreciated.
Allan
Re: Check_Logfiles Plugin Help
You can't assign a variable within an array initialization:
m= 'date +%Y-%m-%d'
You would need to declare that outside of the @searches array, then reference it inside, like so:
my $m= 'date +%Y-%m-%d';
@searches = ({
logfile => "/tmp/DEBUG_${m}.log",
'Device Error',
'System Error',
'Device Stalling ',
Not the double-quotes and curly braces. I have not tested this though - not really sure how the plugin is pulling in the config.
Were you getting any specific errors?
allanhillier
Thank you for the fast response. I did as you suggested and I get the following: It is taking $m as being literally 'date +%Y-%m-%d' and not the actual date values.
UNKNOWN - (1 unknown in dcf_log.protocol-2014-09-17-12-26-23) - could not find logfile /tmp/DEBUG_date +%Y-%m-%d.log
Yea, sorry. Out of habit I changed the backticks to single quotes. It should be:
my $m= `date +%Y-%m-%d`;
allanhillier
I'm getting closer, for some reason whatever is after the variable is lopped off. You will notice a line commented out that I would like to be the actual line that runs. When I was trying the full date there were no underscores only dashes so I think I need to break it out into 3 pieces.
UNKNOWN - (1 unknown in dcf_log.protocol-2014-09-17-13-57-14) - could not find logfile /tmp/DEBUG_2014
my $year=`date +%Y`;
my $month=`date +%m`;
my $day=`date +%d`;
@searches = ({
tag => 'dcfalerts',
logfile => "/tmp/DEBUG_${year}.log",
#logfile => "/tmp/DCF_DEBUG_${year}_${month}_${day}.log",
'Device Error',
'System Error',
'Device Stalling ',
Allan
I'm a bit confused - are you saying that
is not working? That's the part that gets cut off at the year?
If so, just concatenate the three vars together beforehand:
my $day=`date +%d`;
my $date = $year . "_" . $month . "_" . $day;
@searches = ({
tag => 'dcfalerts',
logfile => "/tmp/DEBUG_${date}.log",
'Device Error',
'System Error',
'Device Stalling ',
allanhillier
I ended up having to do this to get it to work: I had to use chomp because for some reason when I thought it was lopping off the rest of the string it was in fact putting it on the next line. I stumbled upon this while troubleshooting by printing the variable $logfile:
Before using chomp it would be -
/tmp/DEBUG_2014
_09
_18
By Adding "chomp"-
/tmp/DEBUG_2014_09_18.log
Hope this makes sense, below is my updated config file that works as expected.
my $day=`date +%d`;
chomp($year);
chomp($month);
chomp($day);
my $logfile="/tmp/DCF_DEBUG_".${year}."_".${month}."_".${day}.".log";
@searches = ({
tag => 'dcfalerts',
logfile => "${logfile}",
'Device Error',
'System Error',
'Device Stalling ',
Thank you so much for taking the time to help, I'll pay it forward if I see someone with a problem that I can help with.
Allan
Good old chomp saves the day again! I'll close this up now, but don't hesitate to come back with any other questions.
