Modify contacts for several services
I have a host which I plan to use as a template for bulk importing and need to change the contact group for all the services. Is there a way to change all the services, I have 9 right now, at one time or do I need to change each service one at a time? I tried to figure out the bulk modification but that doesn't appear to be what need or is it?
Re: Modify contacts for several services
Bulk Modifications is what you want. There is no "change" option - you need to remove the old contact then add the new one.
Gotcha! I was making it harder than what was needed.
Got it all fixed up?
