Hard and Soft issue
Hard and Soft issue
Look at this:
Look at the Unknown at 1:28 and 22:27. They are both 2 of 3 but both say HARD. Shouldn't they be SOFT? Then it doesnt check again in one minute as it should. Or it may have, but didn't log a state change.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
- Box293
- Too Basu
Re: Hard and Soft issue
Can you show us the advanced tab of each of these services please.
Advanced Status Details
Service State: Ok
Duration: 5h 50m 19s
State Type: Hard
Current Check: 1 of 3
Last Check: 2014-09-24 15:20:12
Next Check: 2014-09-24 15:25:12
Last State Change: 2014-09-24 09:30:12
Last Notification: Never
Check Type: Active
Check Latency: 0.15918 seconds
Execution Time: 0.55375 seconds
State Change: 0%
Performance Data:
Service Notes:
Service notifications are disabled2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
Can you post the service's config?
host_name xxxxxxxx-uk-gw
service_description ITC-CHI-VPN Tunnel Status
check_command check_netscreen_vpn!-C itc-net -n ITC-CHI-VPN -t!!!!!!!
max_check_attempts 3
check_interval 5
retry_interval 1
notification_interval 0
notifications_enabled 0
contacts dummy_contact,nagiosadmin,sdnagios
contact_groups ACRD_NAGIOS_ALL_CG
register 1
- Box293
- Too Basu
Yeah thanks for that.
It's in a hard state and it reports "Current Check: 1 of 3", similar to your screenshot.
Do you feel like deleting retention.dat, restarting nagios and see if that helps? Or at least removing one of these objects from retention.dat.
These were all just added to nagios the day this happened, so not sure what deleting them from retention will accomplish in this case.
I mean, I'll do it, but don't see it doing anything different since they were just added.
BanditBBS, did you try deleting retention.dat? Did this change anything?
