2014R1.4 upgrade issue
da1701d
Post by da1701d »
The install was going right along but then stops at this point. When I restart the install it still stops at the same place. Anyone have know how resolve this problem? As you can see I already have both the "aclocal-1.11" and "automake" packages.
thanks.
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /tmp/nagiosxi/subcomponents/nagiosplugins/nagios-plugins-2.0.2/build-aux/missing --run aclocal-1.11 -I gl/m4 -I m4
This Perl not built to support threads
Compilation failed in require at /usr/share/automake-1.11/Automake/ChannelDefs.pm line 23.
BEGIN failed--compilation aborted at /usr/share/automake-1.11/Automake/ChannelDefs.pm line 26.
Compilation failed in require at /usr/share/automake-1.11/Automake/Configure_ac.pm line 26.
BEGIN failed--compilation aborted at /usr/share/automake-1.11/Automake/Configure_ac.pm line 26.
Compilation failed in require at /usr/bin/aclocal-1.11 line 39.
BEGIN failed--compilation aborted at /usr/bin/aclocal-1.11 line 39.
WARNING: `aclocal-1.11' is missing on your system. You should only need it if
you modified `acinclude.m4' or `configure.ac'. You might want
to install the `Automake' and `Perl' packages. Grab them from
any GNU archive site.
cd . && /bin/sh /tmp/nagiosxi/subcomponents/nagiosplugins/nagios-plugins-2.0.2/build-aux/missing --run automake-1.11 --gnu
Compilation failed in require at /usr/bin/automake-1.11 line 139.
BEGIN failed--compilation aborted at /usr/bin/automake-1.11 line 144.
WARNING: `automake-1.11' is missing on your system. You should only need it if
you modified `Makefile.am', `acinclude.m4' or `configure.ac'.
You might want to install the `Automake' and `Perl' packages.
Grab them from any GNU archive site.
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /tmp/nagiosxi/subcomponents/nagiosplugins/nagios-plugins-2.0.2/build-aux/missing --run autoconf
configure:49746: error: possibly undefined macro: gl_IDPRIV
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
make: *** [configure] Error 1
[root@nagios-test nagiosxi]# perl -v
This is perl, v5.8.8 built for x86_64-linux
Copyright 1987-2006, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl". If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
[root@nagios-test nagiosxi]# uname -a
Linux nagios-test.wz.hasbro.com 2.6.32-358.18.1.el6.x86_64 #1 SMP Wed Aug 28 17:19:38 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
[root@nagios-test nagiosxi]# cat /etc/redhat-release
CentOS release 6.4 (Final)
[root@nagios-test nagiosxi]# yum install automake autoconf
Loaded plugins: fastestmirror, security
Loading mirror speeds from cached hostfile
* base: ftp.osuosl.org
* epel: ftp.osuosl.org
* extras: mirror.web-ster.com
* rpmforge: mirror.hmc.edu
* updates: centos.expedientevirtual.com
Setting up Install Process
Package automake-1.11.1-4.el6.noarch already installed and latest version
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
Nothing to do
Re: 2014R1.4 upgrade issue
Do you have "pkgconfig" installed?
yum list installed | grep pkgconfig
da1701d
Post by da1701d »
[root@nagios-test ~]# yum list installed | grep pkgconfig
pkgconfig.x86_64 1:0.23-9.1.el6 @anaconda-CentOS-201112091719.x86_64/6.2
Yep.
Post by Box293 »
How about trying a re-install of these packages:
yum reinstall automake autoconf
