NCPA CPU Check
AMacintosh
NCPA CPU Check
Post by AMacintosh »
I am curious as to how other Nagios NCPA users are using the CPU check?
We are currently getting alerted for a CPU issue on a Windows host that does not appear to have an overall CPU Usage issue. It looks like one of the CPU's or cores may be utilized..
CRITICAL: percent was 0%,0%,0%,100%,0%,0%,0%,0%
Re: NCPA CPU Check
What is the NCPA version that you are currently using? Can you show us the actual command that you are running from the command line, along with the output of it?
Example:
[root@testbox libexec]# /usr/local/nagios/libexec/check_ncpa.py -H 192.168.x.x -t 'token' -P 5693 -M cpu/percent -w 20 -c 40
WARNING: percent was 27%,0%,28%,0%,18%,0%,0%,3% | 'percent_0'=27%;20;40; 'percent_1'=0%;20;40; 'percent_2'=28%;20;40; 'percent_3'=0%;20;40; 'percent_4'=18%;20;40; 'percent_5'=0%;20;40; 'percent_6'=0%;20;40; 'percent_7'=3%;20;40;
AMacintosh
Re: NCPA CPU Check
We are using the following command which seems to alert if a single CPU or Core is over the threshold rather than reporting on the overall usage.
/usr/local/nagios/libexec/check_ncpa.py -H 0.0.0.0 -t '<token>' -P 5693 -M cpu/percent -w 85 -c 95
Re: NCPA CPU Check
You are correct. This is how CPU check is working at the moment. It's a known issue. You can check out this post:
https://github.com/NagiosEnterprises/ncpa/issues/56
AMacintosh
Re: NCPA CPU Check
Has anyone implemented a fix so that it gets an aggregate instead of alerting if a single core meets the threshold? This is causing a lot of false alerts.
Re: NCPA CPU Check
I don't think so. I expect this to be implemented in the next version of NCPA, but I cannot be 100% sure - it is up to the developer. You can post a question for the developer here: https://github.com/NagiosEnterprises/ncpa/issues/56
