NNA report and queries
rashid2014
Post by rashid2014 »
hello
at beginning when i select a source i could see for exemple Top 5 Talkers By Source IP or Top 5 Talkers By Destination IP or Top 5 Talkers By Source Port Top 5 Talkers By Destination Port bottom of bandwitch graph or when i run a report or check queries. since I integrate NNA wich XI i the table of Top 5 Talkers By Source IP or Top 5 Talkers By Destination IP or Top 5 Talkers By Source Port Top 5 Talkers By Destination Port is empty when a select a source or run a report...
what can cause that please?
Re: NNA report and queries
Can you show us a screenshot of the error? What is the version of the Nagios XI and the Nagios Network Analyzer Component that you are currently using?
rashid2014
hello! please escuse me for the late
i use the latest version of NNA (trial version remaining 10 days) and nagios XI ( trial version ). this is the screenshot. thanks
If you go to the "Reports", do you see the "top 5" talkers? (try different options from the drop-down menu and click on "Run Report)
