./upgrade: line 797: ifconfig: command not found
jbennett
Post by jbennett »
Our Nagios box is behind a bluecoat firewall and is not accessable outside of our intranet.
THis was the last thing spat out before the upgrade returned completed:
Line 797 found below:
ip=$(ifconfig | egrep -1 eth[0-9] | grep -m 1 'inet' | awk '/inet[^6]/{print substr($2,6)}')
Is this anything to be concerned with?
I have set our program URL but have left the external URL blank in Admin -> Manage System Configs
abrist
Red Shirt
Re: ./upgrade: line 797: ifconfig: command not found
Post by abrist »
Does your XI server have the ifconfig command?
which ifconfig
What distro is it running:
cat /etc/*release
jbennett
Post by jbennett »
Apparently it doesn't have ifconfig
/usr/bin/which: no ifconfig in (/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/etc/opt/emcpower/bin:/home/xxx/xxx/bin)
Red Hat Enterprise Linux Server release 5.10 (Tikanga)
Post by Box293 »
Nothing to worry about here.
It's trying to determine the IP address so it can show you the url to go to:
You can access the Nagios XI web interface by visiting:
	    http://$ip/nagiosxi/
jbennett
Post by jbennett »
Thanks!
sbin is missing from $PATH. The path should look like this:
/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
