Command submitted for processing...
Waiting for configuration verification..................................................
Configurations failed to write to file.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
If I re-roll configuration or check it from command prompt, verification goes without error.
Configuration is applied but there is still this error abour Configuration failed to write to file.
Attached are cmd.txt and reconfig.txt
