We recently upgraded from Ubuntu 12.04.4 to 14.04.1(now running Nagios Core 3.5.1 via Ubuntu repository, n2rrd version 1.4.6) and while most everything survived unscathed, the performance scripting is failing without any clue why. I did have some perl packages that were causing headaches, but that has since been resolved. Permissions on the script are execute for all. I can run the script as root with the data that Nagios should be sending without any errors. But nothing from Nagios. I modified the script to dump the passed variables at the beginning of the script - it never dumps anything from Nagios (do get output when run manually). I have tried +epn and -epn with no success. I have placed a very simple script in place, and that script executes. So Nagios config appears to be fine (I didn't expect something to change with that)
So can someone please feed me something to help troubleshoot this? Can I enable troubleshooting so I can see what Nagios may or may not be getting when it should be executing the script? H-E-L-P
Thanks in advance again
Brian
