rrd won't graph
BanditBBS
rrd won't graph
Post by BanditBBS »
Ok, on to an issue with the part of Nagios I understand the least, the graphing!
This is on a 2012r2.9 server FYI.
I have a server where all graphs are populated except for one, the check_disk. Here is the perfdata:
/=526MB;808;909;0;1011 /dev/shm=0MB;6494;7306;0;8118 /tmp=245MB;1612;1813;0;2015 /usr=12863MB;11809;13285;0;14762 /var=474MB;1612;1813;0;2015 /u01=41550MB;37554;42248;0;46943 /u02=7522MB;60080;67590;0;75101 /u03=101665MB;122684;138020;0;153356
All the charts on performance charts tab or in graph explorer show up empty. I imagine if I deleted the rrd it would probably work again, btu I'd prefer not to lose all the history...any hints on things I could try?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: rrd won't graph
Have you modified the check prior to noticing the issue? Can you show us the service definition? Are you using the "default check_disk" plugin? What is version of the plugin that you are using?
./check_disk -V
BanditBBS
Re: rrd won't graph
Post by BanditBBS »
check_disk (nagios-plugins 1.4) 1.56
Its a passive check, so nothing really of importance in the service config, let me know if you still want to see it. The check is run every 5 minutes and sent via nsca.
The check command is:
check_disk -w 20% -c 10% -e
abrist
Red Shirt
Re: rrd won't graph
Post by abrist »
Did the number of mount point that are being checked change? You may have run into a datasource quantity mismatch. Check the perfdata.log for any errors pertaining to this check.
