In XI, I would like to setup screen/dashboard if user logs in should be able to see production & test servers.
But, as soon as he lands on dashboard page he should see only production servers.
in this case can I create two host group & use multi tenant feature. what is the solution here.
Customer screen for prod/test
Re: Customer screen for prod/test
I'm not sure what you mean by that. You can't have a dashboard both show and not show test servers. Can you explain in more detail what you are trying to do?
krobertson71
Are you trying to set it up to where you have 1 dashboard showing both Production and Test servers and depending on the user they can see one or both?
@lafargeuser
Can you elaborate?
Can you elaborate?
