Hi everyone,
I'm trying to configure monitor to Oracle.
We got this result:
CRITICAL - cannot connect to 192.168.1.51:1521/SIP. install_driver(Oracle) failed: Can't locate DBD/Oracle/Object.pm in @INC (@INC contains: /usr/local/nagios/libexec /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/
What am I doing wrong?
PROBLEM WITH ORACLE PLUGINS
Re: PROBLEM WITH ORACLE PLUGINS
Did you install the "DBD::Oracle" module? Try fixing the issue by running:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
export ORACLE_HOME=<path to your Oracle which was given by the script>
export LD_LIBRARY_PATH=$ORACLE_HOME/lib
cpan -i DBD::OracleBe sure to check out our Knowledgebase for helpful articles and solutions!
soporte.impala
Hey mate,
yes i did it but just doesnt work
So you were able to install the "DBD::Oracle" module successfully, but this didn't solve your issue? Can you run the following command and show us the output?
perldoc -l DBD::OracleBe sure to check out our Knowledgebase for helpful articles and solutions!
soporte.impala
Hey mate, ty for your answer.
Command result are:
-bash-4.1# perldoc -l DBD::Oracle
/usr/local/lib/perl5/DBD/Oracle.pm
-bash-4.1#
Command result are:
-bash-4.1#
Actually, I just found out that you have a support ticket open already in our email ticketing system. It is better if we follow this case in one place.
Please, email us the profile.zip, so that we can review your configs. Thank you!
I am locking this topic.
