ndo2db trucate table restart indexes
andrea.manica
Post by andrea.manica »
I've installed nagios 4.08 with ndo utils
when i restart nagios all hosts and all hosts groups where deleted and created.
is possible to change the configuration in order to mantain data when nagios restart.
thanks
Andrea
Re: ndo2db trucate table restart indexes
I'm not sure what you mean by "deleted and created". Do you mean they were, for example, in an OK state and then after the restart they were in a Pending state or something similar?
andrea.manica
It 's like a truncate table.
When I restart nagios form the same configuration file the nagios_host table was truncated and then re pupolated using different id for hosts.
and this is for all the tables.
abrist
Red Shirt
Post by abrist »
Have you changed the ndo instance in the ndo2db.cfg?
Can you show us the logs of these truncations?
