NRPE help - Return code 127
tgrtjake
Post by tgrtjake »
I have Nagios 4.0.8 running on Ubuntu 14.04 and am trying to monitor more than just ping on a remote Ubuntu 14.04 host. Any help?
I am getting the following error from the webpage:
Return code of 127 is out of bounds - plugin may be missing
nagios owns the plugin:
-rwxr-xr-x 1 nagios nagios 22992 Sep 25 15:03 check_nrpe
This is service defined in the cfg for the server being monitored:
host_name remotehost01
service_description Root Partition
check_command check_nrpe!check_root!
Here is check_nrpe defined in commands.cfg:
command_name check_nrpe
command_line $USER$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Here is part of the /etc/nagios/nrpe.cfg on the remote host:
command[check_users]=/usr/lib/nagios/plugins/check_users -w 5 -c 10
command[check_load]=/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
command[check_hda1]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/hda1
command[check_root]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/remotehost01-root
command[check_zombie_procs]=/usr/lib/nagios/plugins/check_procs -w 5 -c 10 -s Z
command[check_total_procs]=/usr/lib/nagios/plugins/check_procs -w 150 -c 200
And here is output when manually running the check from the nagios server:
root@NAGIOS01:/usr/local/nagios/etc/objects/ccc/servers# /usr/local/nagios/libexec/check_nrpe -H 172.16.x.x -c check_root
DISK OK - free space: / 24587 MB (89% inode=94%);| /=2781MB;23085;25971;0;28857
Nagios Core 4.1.1 running on Ubuntu 14.04
Re: NRPE help - Return code 127
What are the permissions of /usr/lib/nagios/plugins/check_disk on the remote host?
tgrtjake
Post by tgrtjake »
Everything in /usr/lib/nagios/plugins on remote host is root. Should it be nagios?
-rwxr-xr-x 1 root root 126016 Jul 5 2013 check_disk
tgrtjake
Post by tgrtjake »
Bah, I see now what was wrong. The defined command had a typo.
Changed from:
To:
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Ooooh, subtle. I always hate stuff like that. But hey, glad to see it's working. Gonna lock this up now.
