My manager has asked me to investigate how we can get web analytic for the Nagios XI Web server. Examples would be:
1. How many hits/hour do we get?
2. Where are they coming from?
3. Who are they (IP Address)?
Is there a way to do this as part of the product?
Regards,
Randy.
Web analytics
- Box293
- Too Basu
Re: Web analytics
I think the best way to get this information will be from the Apache access logs.
I also think we might have a solution for this, but I will need to get back to you in a couple of days if that's OK?
intelXIadmin
Re: Web analytics
Thank you for the reply. I'll wait to see if Nagios itself has a solution.
Regards,
Randy.
Regards,
Randy.
Re: Web analytics
This sounds like a perfect use case for Nagios Log Server.
Otherwise, you will need to look at check_log_files:
https://labs.consol.de/nagios/check_logfiles/
