Updated Configuration Wizards
adam.sage
Post by adam.sage »
Are there plans to update the configuration wizards to include recent software releases of Exchange and VMWare VCenter?
abrist
Red Shirt
Re: Updated Configuration Wizards
Post by abrist »
Yes, though we do not have roadmap for them yet. Unless the SDK has significantly changed, the current VMWare wizard should still work. MS Exchange is monitored by checking certain services and external ports. So there is a good chance the current wizard may work as well.
adam.sage
Post by adam.sage »
I just went through the VCenter wizard again and all the plugins are showing: (No output returned from plugin) My VCenter server is version 5.1.0 1123961
The VMware ESXi host monitoring seems to work ok, hosts are version 5.1.0 1065491
Exchange works but the Core Services shows critical and OWA Status has changed a bit so it shows HTTP WARNING: HTTP/1.1 403 Forbidden - 1412 bytes in 0.001 second response time. I'm not sure what the parameters are for this command check_xi_service_http! -H exchange.ad-qsv.qualitystoneveneer.com -f ok -I 10.0.8.91 -u "/exchange/" but I'm assuming if I change it to the correct address of my OWA it will fix that.
Most probably you will need to change the -u "/exchange/" to the correct address in your installation.
