MountPoint is CRITICAL
madhuneal
Post by madhuneal »
Hello Team,
I have recently configured nagios for disk check by defining this command disk_check -- Please find the configuration details below:
use local-service
host_name APP01
service_description u001 MountPoint
check_command check_local_disk!20%!10%!/dev/sdf1
DISK CRITICAL - /dev/sdf1 is not accessible: No such file or directory
Note: I'm not using NRPE to check the disk also I run all my application server with Aws and EBS volumes.
Please let me know what need to look at this time?
Neal.
Re: MountPoint is CRITICAL
Post by slansing »
Is that the true mountpoint? Can you show us a list of them by running:
mount
Can you also share the plugin you are using with us?
What is the output of the following command?
df -h
