I'm getting (no output returned from plugin) messages when trying to monitor my Nagios XI machine. I thought when you initially loaded the machine, it would load what it needed to be able to monitor itself?
Was I wrong about that, or is this a bug?
I'm on Nagios XI 2014 R1.3, with the latest CentOS
Nagios Won't Monitor Itself??
Re: Nagios Won't Monitor Itself??
Which checks specifically are doing this? Are they the standard ones that ship with XI or did you create them yourself?
EnvBroker1
Both, checks I put in and also the pre-setup checks from the system.
Can you show us the actual checks that you are running from the command line, along with the output of them?
EnvBroker1
This problem was resolved quite a while back. Sorry for not getting back with you guys.
Thanks for all the great help.
You can close this thread.
