After fixing a bunch of configuration isuess with this upgrade process, I am now having an error without a file being indicated:
(10:24 AM)-> /usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/wescef.cfg'...
.... 820 lines deleted as they have no errrors....
Processing object config file '/usr/local/nagios/etc/services/sys_check_kwi_lun23.cfg'...
Processing object config file '/usr/local/nagios/etc/services/nsc_check_web_netstat.cfg'...
What would be the best way to find out why Nagios is stuck?
Cheers,
Ivica
Nagios upgrade from 2012R2.9 to 2014R1.5
Ivica Mustapic
Re: Nagios upgrade from 2012R2.9 to 2014R1.5
If you do not see any descriptive errors, you may have issues with escalations or service/host dependencies. You will most likely want to de-activate these definitions until the upgrade is complete.
Read more about config errors during the upgrade to 2014 here:
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
- Box293
- Too Basu
Also try the following from the command line as it may output more information:
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfgAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Ivica Mustapic
Guys,
Thanks for your input. Disabling Host Escalations and Service Escalations has solved my problem.
Cheers,
Ivica
Cheers,
Ivica
Sounds good! I'll be closing this thread now, but feel free to open another if you need anything in the future!
