Is there an Nagios XI agent that supports RedHat version 7? We attempted to install the redhat version 6 agent and it failed. Anyone have a work arround or working agent?
Mark Koutsos
Senior UNIX System Administrator
360 PARK AVE S, 12TH FLOOR, ROOM 12-022
NEW YORK, NY 10010
EMAIL: [email protected]
DESK (646) 524-0543
CELL (347) 852-0916
Nagios XI LINUX Agent for RedHat Version 7
Mark Koutsos
NEW YORK, NY 10010
DESK (646) 524-0543
CELL (347) 852-0916
FAX (646) 524-0101
NEW YORK, NY 10010
DESK (646) 524-0543
CELL (347) 852-0916
FAX (646) 524-0101
Re: Nagios XI LINUX Agent for RedHat Version 7
Not yet. Can you post the errors from the build?
Under the linux-nrpe-agent directory I modified two of the installation scripts to make them compatible with RedHat7.
./fullinstall ./A-subcomponents
These were doing firewall commands that are no longer work for RedHat Version 7. I am happy to report the agent installed successfully and works with no issues.
See my attached scripts.
Mark Koutsos
NEW YORK, NY 10010
DESK (646) 524-0543
CELL (347) 852-0916
FAX (646) 524-0101
NEW YORK, NY 10010
DESK (646) 524-0543
CELL (347) 852-0916
FAX (646) 524-0101
Thanks, I'll take a look at that - it will surely be helpful in our testing with RHEL/CentOS 7.
Did you run into any errors after the installation?
