Our Nagios XI server crashed this morning, we are not able to access the server via putty and when we try to access the webpage it gives a message saying
Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
Run the following from the CLI as root to attempt to repair the DB
/usr/local/nagiosxi/scripts/repair_databases.sh
/usr/local/nagiosxi/scripts/repair_databases.sh"Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration."
we checked both Postgres and MySQLd and it returned a message saying " postmaster dead but pid file exists" similar message for mysqld.
I have tried to restart the ndo2db process and it gave a error message saying
"service ndo2db start
Starting ndo2db:rm: cannot remove `/usr/local/nagiosxi/var/subsys/ndo2db': Read-only file system
rm: cannot remove `/usr/local/nagios/var/ndo.sock': Read-only file system
touch: cannot touch `/usr/local/nagios/var/ndo2db.lock': Read-only file system
chown: changing ownership of `/usr/local/nagios/var/ndo2db.lock': Read-only file system
Could not bind socket: Address already in use
touch: cannot touch `/usr/local/nagiosxi/var/subsys/ndo2db': Read-only file system
chown: changing ownership of `/usr/local/nagiosxi/var/subsys/ndo2db': Read-only file system
done."
we tried to run a backup
Sthitha Pragna Madhiraju As per the email we received from Aravindhan (Attached), we are asked to submit our goal setting and evaluation to our reviewer and appraiser in Performagic as per the new Org changes and provide the details of the reporting lead to the appraiser for consulting during the evaluation process. Please let me know we are indeed required to send the details to our reporting lead, as we will be completing our implementation next month and the reporting lead might change if we move to a new project.
10:46
/backup_xi.sh
./backup_xi.sh: line 6: ./config.dat: Read-only file system
./backup_xi.sh: line 7: ./config.dat: No such file or directory
[root@eu2napu002 scripts]# pwd
/usr/local/nagiosxi/scriptsCode: Select all
touch: cannot touch `/usr/local/nagiosxi/scripts/repair_databases.lock': Read-only file system
mysqld dead but pid file exists
rm: cannot remove `/var/lib/mysql/mysql.sock': Read-only file system
Starting mysqld: [FAILED]
DATABASE: nagios
TABLE:
/var/lib/mysql/nagios ~
Stopping mysqld: [FAILED]
myisamchk: error: 30 when opening MyISAM-table 'nagios_acknowledgements.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_commands.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_commenthistory.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_comments.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_configfiles.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_configfilevariables.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_conninfo.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contact_addresses.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contactgroup_members.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contactgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contact_notificationcommands.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contactnotificationmethods.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contactnotifications.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contacts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_contactstatus.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_customvariables.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_customvariablestatus.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_dbversion.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_downtimehistory.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_eventhandlers.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_externalcommands.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_flappinghistory.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostchecks.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_host_contactgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_host_contacts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostdependencies.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostescalation_contactgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostescalation_contacts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostescalations.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostgroup_members.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hostgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_host_parenthosts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hosts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_hoststatus.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_instances.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_logentries.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_notifications.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_objects.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_processevents.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_programstatus.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_runtimevariables.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_scheduleddowntime.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_servicechecks.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_service_contactgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_service_contacts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_servicedependencies.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_serviceescalation_contactgroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_serviceescalation_contacts.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_serviceescalations.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_servicegroup_members.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_servicegroups.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_service_parentservices.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_services.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_servicestatus.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_statehistory.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_systemcommands.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_timedeventqueue.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_timedevents.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_timeperiods.MYI'
myisamchk: error: 30 when opening MyISAM-table 'nagios_timeperiod_timeranges.MYI'
REPAIR COMPLETE
DATABASE: nagiosql
TABLE:
/var/lib/mysql/nagiosql ~
myisamchk: error: 30 when opening MyISAM-table 'tbl_command.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_contactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_contact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_contacttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_domain.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_hostdependency.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_hostescalation.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_hostextinfo.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_hostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_host.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_hosttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_info.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactgroupToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactgroupToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContacttemplateToCommandHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContacttemplateToCommandService.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContacttemplateToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContacttemplateToContacttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContacttemplateToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactToCommandHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactToCommandService.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactToContacttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkContactToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostdependencyToHost_DH.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostdependencyToHostgroup_DH.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostdependencyToHostgroup_H.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostdependencyToHost_H.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostescalationToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostescalationToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostescalationToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostescalationToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostgroupToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostgroupToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToHosttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHosttemplateToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToHosttemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkHostToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToHost_DH.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToHostgroup_DH.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToHostgroup_H.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToHost_H.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToService_DS.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicedependencyToService_S.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceescalationToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceescalationToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceescalationToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceescalationToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceescalationToService.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicegroupToServicegroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicegroupToService.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToServicegroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToServicetemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServicetemplateToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToContactgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToContact.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToHostgroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToHost.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToServicegroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToServicetemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkServiceToVariabledefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_lnkTimeperiodToTimeperiod.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_logbook.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_mainmenu.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_servicedependency.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_serviceescalation.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_serviceextinfo.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_servicegroup.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_service.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_servicetemplate.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_settings.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_submenu.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_timedefinition.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_timeperiod.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_user.MYI'
myisamchk: error: 30 when opening MyISAM-table 'tbl_variabledefinition.MYI'
REPAIR COMPLETE
Stopping ndo2db: done.
rm: cannot remove `/usr/local/nagios/var/ndo2db.lock': Read-only file system
done.
