Installation fails on NTP - Solved
toper
Post by toper »
Just for information.
20 Oct 13:39:05 ntpdate[9692]: no server suitable for synchronization found
INSTALLATION ERROR!
I got this issue when i installed on our lab, i'm behind a FW and only port 80 and 443 was open out.
I edited the file fullinstall and put in our own ntp
# Set date/time because ssl certificates can be in the future... (fix for pypi and get-pip)
# ntpdate -u pool.ntp.org
ntpdate -u your_own_ntp_server
br,
Peter Calum,
TDC Denmark
Peter Calum
Re: Installation fails on NTP - Solved
Thanks for the tip. Being a new product there are of course going to be errors we haven't run into in-house, so any input is appreciated!
ischwartz
Post by ischwartz »
Looks like you have a solution, I will lock this up.
