Dear All,
I've found out that CGIs in nagios 3.2.2 (e.g. in extinfo.cgi, in long plugin output) converts successfully \n (written as two characters) to <BR>, while in nagios 4.0.20130912, the conversion is broken.
One reason of the problem is: 'n' in the source code of cgiutils.c in 3.2.2 has been replaced with '\n' in 4.0.20130912 what is obviously not the same.
Also two other related corrections were needed (as new functionality has been added and was affected too).
The fix is in attachment. I hope it will help someone.
Best regards,
Marek Kaminski [ marek.kaminski.1112 (at) gmail.com ]
[patch] fix for conversion of \n to <BR> (in CGIs)
marek.kaminski.1112
cgiutils.c.nagios-4.0.20130912.patch.txt- (1.3 KiB) Downloaded 399 times
Re: [patch] fix for conversion of \n to <BR> (in CGIs)
I'll definitely take a look at this and see if the developers can do anything with it. Thanks for the patch!
marek.kaminski.1112
You're welcometmcdonald wrote:I'll definitely take a look at this and see if the developers can do anything with it. Thanks for the patch!
So thanks for looking what developers can do with it.
Best regards,
I'll leave the topic open for now in case the dev needs to contact you for any reason.
