I wanna kick ELK to the curb!
benhank
Post by benhank »
How would I set up NLS to pull in old logs and data that has already been processed by my ELK stack?
Proudly running:
Nagios Network Analyser
Nagios Fusion
abrist
Red Shirt
Re: I wanna kick ELK to the curb!
Post by abrist »
This is a good question. I am going to pull in a dev on this one. More shortly.
Here's the quick way to accomplish this..
Add the following input to just ONE instance of your Nagios Log Server cluster
Admin -> PER INSTANCE (ADVANCED) -> Select 1 instance -> Add Input
Then, based on this input you will add something like the following to connect to your OLD ELK server
input {
  # Read all documents from Elasticsearch matching the given query
  elasticsearch {
    host => "YOUR_OLD_SERVER_HOSTNAME"
    size => 10000
Then, Apply configuration, and all of data will be pulled into Log Server from your existing ELK stack.
benhank
Post by benhank »
all set can be locked
Proudly running:
Nagios Fusion
