Front End Queue??
Front End Queue??
We are looking to implement a 3 node Nagios Log Server cluster to support our environment. I am concerned that we may generate too much traffic for the logstash processes to handle during peak times. Do you have any suggestions for a receiving queue or the ability to "stack" multiple logstash instances on each node to handle the load should we start dropping data?
Re: Front End Queue??
As logstash is multi-threaded starting additional instances on the same server won't increase throughput, however you could push the data to a queue such as Redis and then have logstash pull from the Redis queue
http://logstash.net/docs/1.4.2/inputs/redis
