Nagios services startup issue using sudo
rajasegar
Post by rajasegar »
NagiosXI 2014R1.2
RHEL 6.5 64bit
DB Offloaded
check_gearman: version 1.4_nagios4 running on libgearman 0.25
I have got a very strange problem.
Nagios services does not start up if using root or sudo.
It only works if nagios id is used or Apply Configuration is done from the gui.
The symptoms
1) gearman_top - check_results worker will be 0 if nagios is started using root.
2) Nagios System dashboard. The last 3 indicators will be blue which is active host checks, service checks and notification.
3) No relevant error messages in any logs.
Does anyone have any clue about this issue?
Did a remote support with the nagios team sometime back and they have no clue either.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: Nagios services startup issue using sudo
Let's clarify - if you are logged in as root, you are not able to stop/start/restart service?
# service nagios stop
# service nagios start
# service nagios restart
What is the output of the following commands?
echo $PATH
grep root /etc/passwd
rajasegar
Post by rajasegar »
lmiltchev wrote:Let's clarify - if you are logged in as root, you are not able to stop/start/restart service?
echo $PATH
If logged on using root. All the nagios service stop, start & restart executes fine without error.
However the start command does not start the services properly.
No idea what service is not started but gearman check_results will be 0.
All other services starts up fine using sudo.
[nagios@nagiosprodxi1 ~]$ echo $PATH
/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/nagios/bin
[root@nagiosprodxi1 ~]# echo $PATH
/usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
[root@nagiosprodxi1 ~]# grep root /etc/passwd
root:x:0:0:root:/root:/bin/bash
operator:x:11:0:operator:/root:/sbin/nologin
RHEL 6 & 7
cmerchant
Post by cmerchant »
Please open an email support ticket at [email protected] and send us your profile.zip.
Admin --> System Profile --> Download Profile
Thanks.
rajasegar
Post by rajasegar »
cmerchant wrote:Please open an email support ticket at [email protected] and send us your profile.zip.
Thanks.
I am creating a duplicate VM for troubleshooting the upgrade issue.
Will open a ticket once it is ready to troubleshoot 2 issues at the same time.
It might be related.
RHEL 6 & 7
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Sounds great, thanks raja!
