Nagios grpah usage
- sundaraminfotech
Nagios grpah usage
Hi All,
I have small query, In my environment we are using pnp4nagios for host & service graphs.
While i'm using pnp4nagios tool for graphs, the default nagios xi integrated graph tool are not generated the host and service graphs. I would like to use both graphs tool in the same time.
It's possible to configure please let me know what are the changes to be done in nagios xi configuration.
Thanks & Regards,
Re: Nagios grpah usage
So you are using PNP for their web interface, and the highcharts graphs for Nagios XI? Or your hosts/services are not displaying graphs? If you could provide a bit more detail that would be great, thanks!While i'm using pnp4nagios tool for graphs, the default nagios xi integrated graph tool are not generated the host and service graphs. I would like to use both graphs tool in the same time.
- sundaraminfotech
Thanks for your reply. FYI, Everything ok in PNP. I need the same graph in highcharts also.
I'm attached xi highchart graph current status for your reference.
Thanks & Regards,
What version of XI are you running?
Are there any apache errors?
tail -50 /var/log/httpd/error_logFormer Nagios employee
- sundaraminfotech
Thanks abrist.
There is no error related to graph. Actually the graph working from pnp4nagios. I want the same graph in nagios xi also.
Thanks abrist.
Thanks & Regards,
- Box293
- Too Basu
abrist wrote:What version of XI are you running?
- sundaraminfotech
What I want to know is what version on PNP4Nagios are you using. If you installed the lastest PNP4Nagios 0.6.x then it breaks XI. XI uses the lastest build for PNP4Nagios 0.4.x.
Grumpy Olde IT Guy
sundaraminfotech, run the following command and show us the output:
cat /usr/local/nagios/etc/pnp/pnp4nagios_releaseBe sure to check out our Knowledgebase for helpful articles and solutions!
- sundaraminfotech
Hi Team,
We are using pnp4nagios latest 0.6.24. What is the process to use both graph tools.
Output - " cat /usr/local/nagios/etc/pnp/pnp4nagios_release "
PKG_REL_DATE="05-02-2009"
PKG_VERSION="0.4.14"
PKG_NAME="pnp"
Thanks & Regards,
