We have a computer database and would like to generate a link to NagioxXI to see detail of a host. I copied a link and noticed it is roughly in this format:
https://ubitmon-hf.hf.intel.com/nagiosx ... =’hostname here not in quotes’. This works only if a session is already established, otherwise you get back a session expired message.
Is there a better link that would bring up the login dialog is not logged in, then go directly to the link?
Regards,
Randy.
URL to host detail from database
Re: URL to host detail from database
Not currently, but you could use the backend api username and ticketid GET parameters to access the url without a password:
http://assets.nagios.com/downloads/nagi ... nd_API.pdf
