Check HP P2000 API
christudorache
Check HP P2000 API
Having an issue with the Check_P2000_API plugin
I downloaded the plugin from http://exchange.nagios.org/directory/Pl ... 00/details and the specific file was check_p2000_api-v1.5.zip
Everytime I run the command, I get the following error:
CRITICAL : Disks 49 OK, Vdisk 6 OK, Temperature 18 OK, Voltage 26 OK, Overall 3 OK, Midplane/Chassis 1 OK, RAID IOM 2 OK, AC Power Supply 2 OK, 7 Critical, Enclosures 2 OK
Has this happened to anyone before, if so were you able to resolve? Let me know. Thank you.
Re: Check HP P2000 API
It looks like the critical is due to the powersupply checks:
Do you see any errors/warnings/etc in the HP web interface for the device?AC Power Supply 2 OK, 7 Critical
christudorache
I do not see any issues with the power supply. What does the 7 signify?
No errors in the event log on the storage SAN.
I checked another storage SAN and received the following:
0K : Disks 49 OK, Vdisk 4 OK, Temperature 14 OK, Voltage 28 OK, Overall 1 OK, Midplane/Chassis 1 OK, RAID IOM 2 OK, AC Power Supply 2 OK, Enclosures 2 OK
hmmm, I don't know where it came from. I just assume that the criticals applied to the hardware check immediately to the left in the output. You did not see any issue on the device's web ui frontend?
- Box293
- Too Basu
Can you post the exact command you are using.
Also, you could probably narrow down the actual part of the plugin that is causing this problem by executing the plugin with the -c argument:
Hopefully only one of these will produce a critical result, which should help narrow down what the "7 Critcal" means
-c Sets what you want to do
status - get the status of the SAN
disk - Get performance data of the disks
controller - Get performance data of the controllers
vdisk - Get performance data of the VDisks
volume - Get performance data of the volumes
Richard_Lian
We are having exactly the same issue. Did you get a resolution to it?
It started happening for us after a recent SAN firmware upgrade.
I can only assume that the SAN is outputting some new additional information that the script does not know how to handle, but it is a little past my skill set on how to resolve it.
Regards,
Richard
Regards,
Richard
Richard_Lian
These are my details if they help at all.
Command
# 'Check HP P2000 SAN' command definition
command_name check_p2000
command_line $USER1$/check_p2000_api.php -H $HOSTADDRESS$ -U username -P 'password' $ARG1$
Checks
host_name SAN A,SAN B
service_description Status
check_command check_p2000!-c status
register 1
service_description Controller CPU
check_command check_p2000!-c controller -S cpu-load -u "%" -w 75 -C 90!!!!!!!
register 1
PHP script is also attached as a txt file.
Regards,
Richard
Command
Checks
register 1
register 1
Regards,
Richard
check_p2000_api.txt- (25.93 KiB) Downloaded 828 times
- Box293
- Too Basu
Richard,
We can probably narrow down the actual part of the plugin that is causing this problem by executing the plugin with the -c argument:
Can you try adding each one of these to your commands to see what one is causing the issue?
volume - Get performance data of the volumesAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Richard_Lian
I have just run through each of the arguments using -c and each one reports "ok" for the relevant return apart from "status" which produces the strange output with an error
It must think there is "7 Critical" on something but it does not appear to be any of the components listed.CRITICAL : Disks 45 OK, Vdisk 4 OK, Temperature 18 OK, Voltage 26 OK, Overall 3 OK, Midplane/Chassis 1 OK, RAID IOM 2 OK, AC Power Supply 2 OK, 7 Critical, Enclosures 2 OK,
- Box293
- Too Basu
I expect that christudorache will report the same behaviour.Richard_Lian wrote:I have just run through each of the arguments using -c and each one reports "ok" for the relevant return apart from "status" which produces the strange output with an error
I think you are spot on. I had a look on the authors website:Richard_Lian wrote:I can only assume that the SAN is outputting some new additional information that the script does not know how to handle
http://www.toms-blog.com/nagios-hp-msa- ... e-monitor/
And the exact behaviour has been reported on this page (the last item at the bottom of the page)
Seeing as the author updates this plugin regularly I suggest the both of you report this behaviour on that page. There really is nothing else we can help with here.
