Unable to receive SNMP TRAP alerts in Nagios core
debbie_d890
Post by debbie_d890 »
I am trying to monitor a linux server using Nagios Core. I have been able to receive the normal service alerts but failed to receive SNMP Trap alerts. Also, I can view the received traps in /var/log/messages as well as in /var/log/snmptt/snmptt.log. But the service TRAP is not turning to the WARNING state as it should be after receiving a trap.
I am in dire need of some help.
My services.cfg looks like this:
register 0
check_period 24x7
max_check_attempts 1
normal_check_interval 15
retry_check_interval 5
active_checks_enabled 1
passive_checks_enabled 1
parallelize_check 1
obsess_over_service 1
check_freshness 0
flap_detection_enabled 1
process_perf_data 1
retain_status_information 1
notification_interval 315360000
notification_period 24x7
notification_options w,u,c,r
notifications_enabled 1
event_handler_enabled 1
is_volatile 1
name snmptrap-service1
register 0
service_description TRAP
is_volatile 1
flap_detection_enabled 0
process_perf_data 0
retry_check_interval 1
check_period 24x7
use snmptrap-service1
host_name XYZ
contact_groups admins
My hosts.cfg :
## Default Linux Host Template ##
name linux-box1 ; Name of this template
use generic-host ; Inherit default values
check_period 24x7
check_interval 5
retry_interval 1
max_check_attempts 10
notification_interval 30
notification_options d,r
register 0 ; DONT REGISTER THIS - ITS A TEMPLATE
## Default
use linux-box1 ; Inherit default values
host_name XYZ ; The name we are giving to this server
alias xyz
address xxx.xxx.xxx.xxx
snmptt.conf
EVENT psAlarmNoDirectoryRequesterProtocolSpecified .1.3.6.1.4.1.23372.1.1.0.1000 "Status Events" Normal
FORMAT A psAlarmNoDirectoryRequesterProtocolSpecified trap $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" " A device has failed"
EXEC /usr/local/nagios/libexec/eventhandlers/submit_check_result $r TRAP 1 "A psAlarmNoDirectoryRequesterProtocolSpecified trap $*"
SDESC
signifies that no proper directory access protocol,
e.g. ldap, specified which result in unable to request
directory server
EDESC
EXEC /usr/local/nagios/libexec/eventhandlers/submit_check_result $r TRAP 1 "A psAlarmNoInitialContextFactorySpecified trap signifies $*"
SDESC
that no directory factory class specified, e.g.
com.sun.jndi.ldap.LdapCtxFactory
EDESC
EVENT psAlarmMalformedDirectoryURL .1.3.6.1.4.1.23372.1.1.0.1002 "Status Events" Normal
FORMAT A psAlarmMalformedDirectoryURL trap signifies that the $*
EXEC /usr/local/nagios/libexec/eventhandlers/submit_check_result $r TRAP 1 "A psAlarmMalformedDirectoryURL trap signifies that the $*"
SDESC
directory access universal resource location is not
constructed properly
EDESC
........ etc.
snmptrapd.conf
traphandle default /usr/sbin/snmptt
disableAuthorization yes
donotlogtraps yes
/var/log/snmp/snmptt.log
hu Oct 30 11:17:57 2014 .1.3.6.1.4.1.23372.1.1.1000 Normal "Status Events" sstoresafe1 - A notifyNoDirectoryRequesterProtocolSpecified trap test is on
Thu Oct 30 11:17:57 2014 .1.3.6.1.4.1.23372.1.1.1000 Normal "Status Events" sstoresafe1 - A notifyNoDirectoryRequesterProtocolSpecified trap test is on
"snmptt.log" 6L, 91
Please any help to fix this would be appreciated. I cannot figure out where I am going wrong.
Thanks so much.
-D
Re: Unable to receive SNMP TRAP alerts in Nagios core
Post by Box293 »
If the traps are hitting the /var/log/snmp/snmptt.log then it is recognizing them.
Are the events being recorded in /usr/local/nagios/var/nagios.log ?
You might need to enable log_passive_checks=1 in nagios.cfg to get some more detail as to what is going on.
rhassing
Post by rhassing »
Could you also provide the output from 'grep -i snmptrap /var/log/messages' ?
Rob Hassing
Post by slansing »
Thanks Troy and Rob! @debbie_d890, please let us know when you've got that information, thanks!
