Hi guys,
We are in the process of evaling NagiosXI, I installed the latest version using the installer package on a CentOS server the other day and so far I’m very impressed, however when I try to get into the Nagvis section I get –
Not Found
The requested URL /nagvis/ was not found on this server.
________________________________________
Apache/2.2.15 (CentOS) Server at --------------- Port 443
Any suggestions? I’m not much of a Linux guy so didn't want to go poking around without asking first!
Nagvis not found on new XI deployment
Re: Nagvis not found on new XI deployment
Was this just a minimal centos system? 6.4? 6.5? I'd like to try to replicate this. Anything specific you did to the server, besides install wget, and download/install XI?
Hey,
It was this EC2 AMI - CentOS 6 x86_64 (2014_09_29) EBS HVM-74e73035-3435-48d6-88e0-89cc02ad83ee-ami-a8a117c0.2 (ami-30ff5c47). So 6.5 and I believe from this (https://aws.amazon.com/marketplace/pp/B ... nc2=h_l3_c) that it is a minimal install yes.
Yep just installed wget and then install the XI package, was a very painless install! Is there a log file somewhere that I can grab and upload for you?
sreinhardt
- -fno-stack-protector
Yes please! There should be an install.log in the nagiosxi/ directory if it still exists.Is there a log file somewhere that I can grab and upload for you?
Same issue here, followed the guide for install.
Tried repairing nagvix as per guides best i can get is graphviz-gd-2.26xxxxxxxx has requires of, libcdt, libgraph.so, libgvc.so etc etc.
If you require logs let me know would love to get this working.
hmmm, looks like a bug. I just created a bug report internally for this as I was able to recreate the issue.
Hi
I also have not established navgis ... becoming all the instructions. Rather, it used to be, disappeared after the transfer and update on the new server to version Nagios XI 2014R1.5.
This was a bug in the previous version of Nagvis component to fix, perform the following
Download the new nagviz component attached Install the component through Admin -> Manage components
Run the following from the command line
cd /usr/local/nagiosxi/html/includes/components/nagvis/
./install.shYou do not have the required permissions to view the files attached to this post.
It's okay
Thank you
Thank you
