2 nagios-servers IP in NRPE.cfg
vvz
Post by vvz »
Hi!
I have 2 nagios servers in subnet and number of monitored hosts with NRPE installed.
In nrpe.cfg on each monitored host I put nagios-server1 IP and nagios-server2 IP like this
allowed_hosts=172.16.37.142, 172.16.37.139
Is it possible configuration? or it may cause any problem in the future?
I was using this kind of configuration for more than a month with no problems at all. Just wanna be sure.
Thank you
Re: 2 nagios-servers IP in NRPE.cfg
Post by slansing »
No, you can have multiple addresses, the reason being, you may want to receive checks from multiple Nagios servers. Let us know if you run into issues!
vvz
Post by vvz »
thank you, it makes my life easier
Should we keep this open for you to test or are you okay to close the thread?
