CCM services sometimes not alphabetically ordered
WillemDH
Post by WillemDH »
It seems the services in CCM are sometimes not alphabetically ordered. Anyone else experiencing this issue?
Nagios XI 5.8.1
https://outsideit.net
lgroschen
Re: CCM services sometimes not alphabetically ordered
Post by lgroschen »
If you have Nagios XI 2014 you can click the header of the column to sort the table ascending or descending.
/Luke
WillemDH
Post by WillemDH »
No you can't... It's a longtime standing issue that when sorting in CCM, the search filter is ignored...
Nagios XI 5.8.1
lgroschen
Post by lgroschen »
It does sort the column, as I am testing it on my system (Nagios XI 2014R1.5). Are you saying that it doesn't save the sort when you navigate to a new page?
We've talked about adding this as a feature to retain the column sorts for hosts, services, host groups and service groups. Then maybe when you click the 'Clear' button on the search field it will clear the filters.
/Luke
WillemDH
Post by WillemDH »
I mean when I sort a column, it just shows all the services of all hosts instead of only the services for the host in the serchbox. I clicked clear this afternoon and even that didn't solve it. I had to go to hosts, then back to services for it to only show the services for the host in the searchbox again. The problem I'm describing has been talked about in http://support.nagios.com/forum/viewtop ... hilit=+CCM
But my problems is that services are not alphabetically ordered for some hosts. Maybe it will be solved in CCM 2.2.3.
You can put this thread on hold if you want, I'll let you know if it works after next update.
Grtz
Willem
Nagios XI 5.8.1
lgroschen
Post by lgroschen »
It look like JOmann fixed this in CCM 2.3.3 which will be in 2014R1.6. Can't give you an exact date, but it will be coming out pretty soon.
/Luke
