Error in installation
deepshikha20
I am getting below error while installing the Nagios log server.
ERROR: unable to read system id.
ERROR: your Red Hat installation is not registered or does not have proper entitlements. Please register or enable entitlements at rhn.redhat.com.
My server is not allowed to connect to the internet.
Please advise to skip this step, if possible.
Thanks.
Deepshikha
Thanks.
Deepshikha
Re: Error in installation
Seems issue with RHN registration, please refer the following link to fix,
https://access.redhat.com/documentation ... dm91655248
/Ram
/Ram
In order to properly register your server with the RHN it will need to be online or you will want to follow an offline doc:
https://access.redhat.com/documentation ... fline.html
deepshikha20
is it possible that I can skip the registration since m not allowed to register it ?
What is the dependency of the registration of Server on nagios log server ?
Thanks.
Regards,
Deepshikha
Thanks.
Regards,
Deepshikha
RedHat servers need to be registered with RHN in order to receive updates to software. Since the Nagios installer downloads packages from the repos, it won't be able to do so if you are not registered. From their help page:
Systems must be registered before updates from RHN can be applied
This is a bug that will be fixed in the 2015R1.1 release which is coming really soon. I have attached an updated libinstall.sh file which can be dropped into the extracted install directory and should allow you to install properly on RHEL.
deepshikha20
I am able to run the install command by copying the lib file you have provided , but I get this new error. Please advise.
Exiting, name server cannot be used: Temporary failure in name resolution (-3)11 Nov 11:53:04 ntpdate[16581]: name server cannot be used: Temporary failure in name reso
lution (-3)
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Thanks.
Regards,
Deepshikha
lution (-3)
INSTALLATION ERROR!
Thanks.
Regards,
Deepshikha
Can you post the complete "install.log"?
deepshikha20
Please find the attached file as requested.
Thanks.
Deepshikha
Thanks.
Deepshikha
- Box293
- Too Basu
On line 51 of the fullinstall script the following command is executed:
If you cannot resolve external addresses then I would:
ntpdate -u pool.ntp.org- Double check to make sure the timezone and date/time are correct on the server
Comment out line 5 in the installer
Run fullinstall again
