My Nagios XI affected OpenSSL 'ChangeCipherSpec' Vulnerability, here is my openssl version,
I'm trying to run yum update openssl, but came out this error.[root@localhost ~]# rpm -qi openssl
Name : openssl Relocations: (not relocatable)
Version : 1.0.1e Vendor: CentOS
Release : 16.el6_5.4 Build Date: Thu 09 Jan 2014 02:44:56 AM MYT
Install Date: Wed 12 Feb 2014 07:24:25 PM MYT Build Host: c6b9.bsys.dev.centos.org
Group : System Environment/Libraries Source RPM: openssl-1.0.1e-16.el6_5.4.src.rpm
Size : 4205553 License: OpenSSL
Signature : RSA/SHA1, Thu 09 Jan 2014 06:58:54 AM MYT, Key ID 0946fca2c105b9de
Packager : CentOS BuildSystem <http://bugs.centos.org>
URL : http://www.openssl.org/
Summary : A general purpose cryptography library with TLS implementation
Description :
The OpenSSL toolkit provides support for secure communications between
machines. OpenSSL includes a certificate management tool and shared
libraries which provide various cryptographic algorithms and
protocols.
My NagiosXi version "Nagios XI 2014R1.5"[root@localhost ~]# yum update openssl
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Could not get metalink https://mirrors.fedoraproject.org/metal ... =epel-6&ar ch=x86_64 error was
14: problem making ssl connection
* base: centos.exabytes.com.my
* epel: mirror.smartmedia.net.id
* extras: centos.biz.net.id
* rpmforge: mirror-fpt-telecom.fpt.net
* updates: mirror.smartmedia.net.id
Setting up Update Process
Resolving Dependencies
--> Running transaction check
---> Package openssl.x86_64 0:1.0.1e-16.el6_5.4 will be updated
--> Processing Dependency: openssl = 1.0.1e-16.el6_5.4 for package: openssl-deve l-1.0.1e-16.el6_5.4.x86_64
---> Package openssl.x86_64 0:1.0.1e-30.el6_6.2 will be an update
---> Package openssl-devel.x86_64 0:1.0.1e-16.el6_5.4 will be updated
---> Package openssl-devel.x86_64 0:1.0.1e-30.el6_6.2 will be an update
Dependencies Resolved
Package Arch Version Repository
Size
Updating:
openssl x86_64 1.0.1e-30.el6_6.2 cr 1.5 M
Updating for dependencies:
openssl-devel x86_64 1.0.1e-30.el6_6.2 cr 1.2 M
Transaction Summary
Upgrade 2 Package(s)
Total download size: 2.7 M
Is this ok [y/N]: y
Downloading Packages:
http://mirror.centos.org/centos/6/cr/x8 ... x86_64.rpm: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404 Not Found"
Trying other mirror.
Error Downloading Packages:
openssl-1.0.1e-30.el6_6.2.x86_64: failure: Packages/openssl-1.0.1e-30.el6_6.2.x86_64.rpm from cr: [Errno 256] No more mirrors to try.
openssl-devel-1.0.1e-30.el6_6.2.x86_64: failure: Packages/openssl-devel-1.0.1e-30.el6_6.2.x86_64.rpm from cr: [Errno 256] No more mirrors to try.
