What distro are you on? You should have a /usr/local/nagios/libexec directory by default if you configured the plugins package on Centos/RHEL.
For the top one you posted, you did not follow the directions... you need to use the node package manager, not yum, I suggest you re-read the instructions and try that one out first.
Most likely, the path with nagios-html-email in it is not in the PATH variable for the Nagios server. Ensure the path given by which nagios-html-email is in the PATH of the Nagios server.
root@Nagios objects]# nagios-html-email service http://nagios.example.com | mailx -t
env NAGIOS_CONTACTEMAIL or `-a <address>` must be supplied!
Usage: nagios-html-email [options] <service|host> [arg1] [arg2] ...
This command is meant to be run from nagios when a service or host
experiences problems. The output will be suitable for passing to
a mail program that takes raw email data like `mailx -t`
Options
-a, --address <email> the email address to send mail to, defaults to env NAGIOS_CONTACTEMAIL
-h, --help print this message and exit
-s, --subject <subject> the email subject to use, defaults to _subject for the host/service, or default nagios subject
-t, --template-dir <dir> dir to find ejs template files, defaults to builtin templates
-u, --updates check for available updates on npm
-v, --version print the version number and exit
No message, no subject; hope that's ok
No recipients specified
"/root/dead.letter" 7/186
[root@Nagios objects]#
su nagios
Let us know if you have issues with the nagios account and /bin/login or nologin).
