I am setting up a proof of concept for a client of ours within EC2. I followed the instructions (http://assets.nagios.com/downloads/nagi ... -Cloud.pdf) using the community AMI and I got the server up no problem. Its collecting logs for itself but I setup another host and the logs are not showing up. Well actually 5 cron log messages have come over but there should be a ton of messages.
I made sure the security groups were correct and even temporarily opened all ports just to make sure that was not the problem. I checked the rsyslog config that was created seems correct with the right ip address of the logstash server. I see the log data coming into the server via tcpdump but it never ends up in elasticsearch.
Any ideas?
david
Adding additional logging hosts
Re: Adding additional logging hosts
How long are you waiting? It can take a bit for log entries to be searchable in the dashboards.
I got the server setup this morning around 10 and the other host was up around 11 so >4 hrs.
What is wierd is that I have seen 8 entries come in. All of them from cron. I have restarted services to create logs and also used logger.
- Box293
- Too Basu
Is SELinux enabled on the log server? This can cause issues.
That came to my mind too but I have made sure SELinux is disable in /etc/sysconfig/selinux
I have checked the logstash log and the elasticsearch log and I am not seeing anything that sticks out.
- Box293
- Too Basu
Just to be 100% certain, what does getenforce return when you run it from the cli?
Never hurts to triple check
[ec2-user@ip-172-31-2-181 ~]$ getenforce
Disabled
Disabled
- Box293
- Too Basu
Can you show me a tcpdump on the sending server AND the receiving server.co-dlk wrote:I see the log data coming into the server via tcpdump but it never ends up in elasticsearch.
On the client I ran this command:
[ec2-user@ip-172-31-32-119 ~]$ logger foobar
On the log server I seee this:
[ec2-user@ip-172-31-2-181 ~]$ sudo tcpdump host 172.31.32.119 -A
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
20:21:53.851522 IP ip-172-31-32-119.us-west-2.compute.internal.56137 > ip-172-31-2-181.us-west-2.compute.internal.5544: Flags [P.], seq 309816386:309816440, ack 4221555259, win 211, options [nop,nop,TS val 7287704 ecr 12867034], length 54
E..j..@[email protected].. w.....I...wlB...;....#5.....
.o3...U.<13>Nov 11 01:21:53 ip-172-31-32-119 ec2-user: foobar
20:21:53.852178 IP ip-172-31-2-181.us-west-2.compute.internal.5544 > ip-172-31-32-119.us-west-2.compute.internal.56137: Flags [.], ack 54, win 174, options [nop,nop,TS val 12880814 ecr 7287704], length 0
E..4..@.@.+G...... w...I...;.wlx.....m.....
.....o3.
.....o3.
Hmmm. Not sure what happened but I am starting to see log messages.
I think it may be a security group issue. Need to investigate some more.
