Restore XI different OS?
BanditBBS
Post by BanditBBS »
Ok, my one XI server is on RHEL5. If I use the backup script does it matter if the server I'll restore on is RHEL 5 or 6? It'll be the same bit, 64bit. The XI versions just need to be the same, correct?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Restore XI different OS?
Post by slansing »
That should work fine, the packages would be the big concern, but those are not carried in the backups. The only thing to be really wary of is architecture, specifically pertaining to rrd files, but it sounds like both are 64.
