I have a question, I'm not sure I will be able to explain it in simple words, but I will try my best
I have experience with both Nagios Core & Nagios XI. I used to with Nagios web interface and simple CFG file editing, and I also worked with GroundWork. I'm not sure if you ever heard or know GroundWorks but there is one feature that I was not able to find in Nagios XI. From the GroundWork I was able to create profiles for monitoring.
For example:
I create a host with:
check 1
check 2
check 3
check 4
check 5
check 6
Now From mentioned above, I save it as (name for example) IIS Server Profile.
Now everytime there is a new new host for monitoring with the same checks, I just add the host name to this profile and all the checks will be automatically added to this new host.
In Nagios XI I didn't really found it, but I used "Bulk Host Cloning and Import Monitoring Wizard" which is almost the same idea, but requires few more steps.
So my question is (in case if you understood everything until now) if there is such option to create monitoring profiles or the "Bulk Host Cloning and Import Monitoring Wizard" is the way to do that.
Thanks in advance
