How to specify Windows Service Instance
cvantilborg
Post by cvantilborg »
I am attempting to monitor a service on a Windows host using NSClient++.
The service I am trying to monitor is called 'AOS60$01' because it is the first instance of that service. So my configuration is : check_xi_service_nsclient!WzR774eC!SERVICESTATE!-l AOS60$01 -d SHOWALL
This then returns: AOS60/bin/sh1: Error
What the correct way to monitor this service?
Running as a VM deployed on ESX 64 Bit Version 2014R2.0.
Any help would be appreciated.
Corey Vantilborg
Re: How to specify Windows Service Instance
Try this - click on the service under the "Service Details", click on Configure->Re-configure this service, and modify the command by changing this:
to this:
check_xi_service_nsclient!WzR774eC!SERVICESTATE!-l AOS60\$01 -d SHOWALL
Click on "Update" then schedule a forced immediate check to test it.
cvantilborg
That was the solution. Thank you very much.
Regards,
Corey
I am glad I could help! :)
